98 Air Contitioner problems, AC light blinks
Old Jun 29, 2009 | 07:36 PM
The system pressure should not be high enough when the compressor is not running to trigger the high pressure switch. It should normalize down to a fairly low level. It is only when the compressor is running that the high pressure switch should activate if the pressure is too high.
If the system pressures are proper, then the high pressure switch may be going bad. If the switch is bad, then the system will need to be evacuated prior to attempting to replace the switch.
Old Jun 29, 2009 | 08:09 PM
Antax's Avatar
Antax is on a distinguished road
Thats what I thought you were going to say
Senshi09
40
Aug 21, 2011 01:48 PM
EXKid
Feb 7, 2011 09:19 PM
mousel
Aug 1, 2010 09:56 AM
hitechracing
Sep 1, 2009 11:52 AM
LS Blazer
Jan 7, 2008 02:20 PM
