98 BLaser LS 4.3L Vortec cranks but no start
Old Feb 5, 2016 | 03:12 PM
Athlon2012's Avatar
Athlon2012 is on a distinguished road
I have done a fuel pressure test from the service port after changing fuel filter and here are my results...still no start...
Old Feb 5, 2016 | 04:42 PM
That's the first half of the test. It basically tells us the fuel pump is building at least 62psi, and it holds, but that's all it tells us. Without the results from the second half, we can not correctly diagnose the fuel delivery system. The second half of the test is explained in the link in post #2.
In post #8, your testing method to see if the injectors squirt fuel would be fine, only IF you were actually trying to start the engine. Just turning the ignition to the "RUN" position without engaging the starter, the injectors should not squirt fuel. SO, try your method again while cranking, and make sure all injectors squirt fuel. Both steel fuel lines must be connected to the fuel metering block while doing this test.
Old Feb 5, 2016 | 04:46 PM
Athlon2012's Avatar
I tested each injector while turning over they all spit fuel still no start..
Old Feb 5, 2016 | 05:15 PM
Disconnect the coil wire from the distributor cap. Slide the boot back a bit to expose the terminal. Prop the wire up so there is a half inch gap to ground. Attempt to start the engine. The spark must jump the gap with a bright blue spark, not orange.
Old Feb 6, 2016 | 12:23 PM
Athlon2012's Avatar
Blue spark coming out of the coil...
Old Feb 6, 2016 | 12:24 PM
Athlon2012's Avatar
Also bought a OBD2 Reader to try to check for codes, no available codes are coming up
Old Feb 6, 2016 | 01:08 PM
How old, how many miles, and what brand is the distributor cap & rotor?
Old Feb 6, 2016 | 01:40 PM
Athlon2012's Avatar
150K miles brand new distribtuer cap and rotor.. from autozone Just replaced less than 2K miles ago no signs of burn at all, Just tested the cam sensor, and coil all are working properly. still no start...about to SHoot it with a gun
Old Feb 6, 2016 | 01:57 PM
CWBDDSPC's Avatar
CWBDDSPC is on a distinguished road
The Captain will tell you Autozone stuff is crap and get some AC Delco...
Sorry, yes I have nothing better to do at the moment
Old Feb 6, 2016 | 02:34 PM
Carnac, I love it .
You've got fuel pressure, the injectors are squirting fuel, and you have good spark from the ignition coil. There are a couple of possibilities: #1. Spark plug wires open, or shorting to ground, and #2. I wouldn't trust the AZ cap & rotor. There are several posts here on the forum, with symptoms exactly like you described, that were cured with an AC Delco cap & rotor. See if they will let you pay the difference to upgrade.
99YukonDenali
Feb 16, 2014 02:37 PM
98BlazerSL
Apr 7, 2012 08:03 PM
bsbob
Jul 22, 2011 12:48 PM
dfehrman
Mar 7, 2010 05:41 AM
nyjeepman
34
Mar 15, 2009 07:40 PM
