98 blazer 2wd - front wheel bearing problem
Old Oct 20, 2010 | 12:56 PM
dbaas's Avatar
dbaas is on a distinguished road
Default 98 blazer 2wd - front wheel bearing problem
Bought the car with 100K on it, and it has always had the loud hum from front end. Sound will disappear with a sharp lane change - left or right. So assuming that implies both bearings are bad. Have not checked for vertical play on wheels when jacked up.
Question is - how hard is the job w/o air tools, should alignment be done afterwards, and any parts recommends would be very helpful.
Quote was $340 including labor - not sure if Duralast or Timkin - assuming the cheaper of the two.
Old Oct 20, 2010 | 03:40 PM
robertr728's Avatar
robertr728 is on a distinguished road
Really pretty easy IMO. Heres the Mitchel instructions. But if you have ever done disc breaks on a 2 wheel drive and replace the front rotors its really not much harder to do the bearings too. And i have never done a front end alighnment after messing with front rotors or bearings youll be fine without it.
Old Oct 20, 2010 | 07:27 PM
cage47's Avatar
cage47 is on a distinguished road
Seriously. Like 728 said. If you've done the breaks, taking the few extra steps to do the bearing hub is no big deal. Save about $150 from that quote. 2wd is easy.
brianp
Jun 1, 2020 10:30 AM
Tim Cyrus
Oct 5, 2017 05:55 PM
BlackBlaze
Dec 13, 2013 04:06 PM
ComputerNerdBD
Aug 30, 2011 10:59 PM
ComputerNerdBD
Tires and Wheels
Mar 5, 2011 05:50 PM
