98 blazer climate control help
Old Aug 8, 2011 | 06:37 PM
stanj's Avatar
stanj is on a distinguished road
Default 98 blazer climate control help
just changed out my climate control on my 98 blazer,nothing was working before except my compressor was on, now that the control panel is replaced everthing is working except my compressor is not coming on any advice checked all fuses they are good numbers are around the temp
Old Aug 8, 2011 | 06:40 PM
*Moving to 2nd Gen Tech* - Please read the section descriptions & choose the most appropriate section for your question. The Forum Help & Suggestions Center is for forum software & layout related questions/suggestions.
You didn't happen to blow a fuse in the swap did you?
Do you have automatic temperature control (#'s around the temperature control ****) or manual (just red & blue around the temperature control ****)?
Old Aug 8, 2011 | 06:59 PM
stanj's Avatar
checked all fuses, they are good, there are numbers around the temp
Old Aug 8, 2011 | 07:03 PM
And you've tried hitting the a/c button with the mode selection appropriate for the A/C to operate (either bi-level, vent, or defrost)?
Old Aug 8, 2011 | 07:08 PM
stanj's Avatar
selected a.c. it lights up but compressor want kick in
Old Aug 8, 2011 | 07:14 PM
Can I assume that it is hot enough for the compressor to kick on and that the temperature **** is on it's coldest setting? Was the replacement HVAC control head new?
Could be a problem with the interior and/or exterior temperature sensor... A scan tool would help in diagnosis.
Old Aug 8, 2011 | 07:33 PM
pettyfog's Avatar
May not determine anything but let's establish something:
Remove cycling sw connector from accum and, with ac selected, ground each pin and see if clutch engages.
If it does, jump the pins and see what happens
rickstuart
Aug 17, 2012 10:09 AM
kota04sxt
Dec 10, 2009 09:34 PM
guyd_15
Jun 15, 2009 01:34 PM
seemerollin
Apr 6, 2006 11:22 PM
magtec
Apr 6, 2006 09:54 PM
