98 blazer no spark
Old Aug 8, 2010 | 08:31 PM
shaner63's Avatar
shaner63 is on a distinguished road
Default 98 blazer no spark
Hello everyone. My blazer will not get spark! At the harness that plugs into the coil, I get power with the key on, but shouldn't the other wire pulse while cranking? it's not. It's got a new ICM, rotor, cap and wires. any thoughts? I'm thinkin Crank position sensor.
Old Aug 8, 2010 | 08:47 PM
How are you testing for spark?
If the CKP sensor were faulty, it should set a code.
Old Aug 9, 2010 | 07:25 AM
shaner63's Avatar
First I used a test light at the end of the coil wire, (where it plugs into distributor) then at the coil, now I'm checking the harness that plugs into the coil. Am I correct with my info on this harness? I know one of those wires should pulse while cranking, which one? The pink stays on steady w/ key on, then while cranking no pulse. there is pink and white/black stripe. I thought the white wire should pulse. As far as codes, the check engine light is on, but I cant drive it anywhere to pull codes. All relevant fuses are good.
And thanks for replying!
Last edited by swartlkk; Aug 9, 2010 at 09:52 PM. Reason: *Consecutive Posts* - Please use the edit feature to add more information to your post if another member has yet to reply.
Old Aug 9, 2010 | 09:54 PM
I wouldn't be testing it the way you are. A jumper wire with aligator clips on the ends to ground a spark plug is all you need to test the coil. Put a spark plug wire onto the coil, then a plug into the other end. Ground the plug and watch for a spark as you turn the engine over.
Old Aug 12, 2010 | 07:39 AM
shaner63's Avatar
I've already done that and have determined there's no spark, and am trying to determine why. Can someone clarify: which wire on the harness that plugs into the coil is supposed to pulse while cranking?
Old Aug 12, 2010 | 05:45 PM
Here is the schematic for your vehicle:
JavierEscalonJr
Oct 14, 2020 11:38 PM
blazzer
Jun 4, 2013 04:40 PM
abe_f
Apr 1, 2013 11:19 PM
Yankee Team1020
23
Aug 3, 2011 08:05 AM
jerickso
Apr 13, 2006 02:24 PM
