98 Blazer runs better with plug wires out of order
Old 04-20-2009, 10:23 PM
Fishin_Freak's Avatar
Fishin_Freak is an unknown quantity at this point
Talking
Here's a real kick in the groin guys. I was wiring by the Chilton's manual, section 2-8 fig. 18. It shows High Voltage Switch for all 1996-99 4.3L engines back to front wiring on that side to be 5,1,3 to 5,1,3. Page 2-4 Fig.9 High Voltage Switch system operational schematic for all 1996-99 4.3L engines is 5,1,3 to 5,3,1. I had it right!!! Why do the figures differ? Colby's schematic is right, but it doesn't match the schematic on page 2-8. Chilton's must really love to screw with us that know just enough to be dangerous!!! Any ideas why they would put differing schematics for the same system? Thanks for all of your help guys! Couldn't have ever figured it out without your help! God bless the Blazer forum!
Old 04-21-2009, 08:11 AM
Colby 04's Avatar
Colby 04 is on a distinguished road
That's strange...glad it helped. Take a sharpie and X out that other drawing in your manual that way you'll remember next time
Old 04-21-2009, 12:16 PM
Cylinder #'s are Cylinder #'s. The only way they change is if Bank 1 is on the left, but they still go front of engine to back of engine in order...
Glad this is sorted out though.
Old 04-21-2009, 04:14 PM
Yet another reason to stay away from Chilton & Haynes. GM shop manual, Alldata, or Mitchell is the ONLY way to go. Chilton & Haynes are usually ok if you're changing a bulb or doing an oil change, but other than that, they're worthless.
Old 04-22-2009, 12:31 PM
Tony H's Avatar
Tony H is an unknown quantity at this point
They did the same thing with the Ignition unit on the Ford Explorers. One the one side, the distributor and the Engine plugs are the same, on the other side they swap two of them just to make it less intuative. You would think they would have ran some internal wiring in the Distr. so the dist. matches the Engine on both sides of the engine.
Old 04-22-2009, 01:09 PM
While it may be less intuitive, it is not because they decided to make it more difficult for you to work on your vehicle. The tooling to have the traces inside the cap over lap, maintaining proper plastic thicknesses between traces, etc would have made for a more expensive cap. If you look at the design of the cap for the 4.3L side post style, no traces overlap. Not to mention that they labeled the posts to the cylinder numbers...
Heck, look at how it was before. IMO, this is a large step in the intuitive direction over the old way of doing it where you had to know the firing order and wire locations on the cap.
Mrthelaxer
03-20-2013 08:00 PM
chris015
Engine & Internal
07-25-2011 09:13 PM
urbex
01-10-2010 10:47 PM
rogggg1020
09-24-2008 06:53 AM
boulonman
03-05-2007 05:10 AM
Quick Reply: 98 Blazer runs better with plug wires out of order
