98 blazer seems to loose its oomph
Old Jun 14, 2010 | 07:12 PM
apross44's Avatar
apross44 is on a distinguished road
Default 98 blazer seems to loose its oomph
sorry if there is already a thread on this, but I have a 98 chevy blazer 4wd and I have noticed that after I drive the truck for a while I don't feel like the truck has as much get up and go power as it did when the truck temp was colder.It never goes past the 210 mark on the temp gauge.Could this just be as simple as putting more cold air into the intake or do you guys think that it could be something else? Also I am only getting about 207 miles to my tank (thats running it till my yellow light pops on) is that about normal?
Old Jun 15, 2010 | 07:58 AM
sgg51688's Avatar
sgg51688 is on a distinguished road
cold air will always help the motor. give it a try. im a big fan of holes in the side of the factory air box, onthe side closest to the front/side. as long as you drill holes so that whatever air comes in goes through the filter still, you're good
Old Jun 15, 2010 | 09:09 AM
matt92's Avatar
matt92 is on a distinguished road
invest in a cold air intake. I have one on mine and ive noticed increases acceleration and it gives it a great sound.
Old Jun 17, 2010 | 02:47 AM
apross44's Avatar
i dont want to spend an arm and a leg on a cold air system, can I just make my own by piping off of the I think map air flow sensor (or what ever sensor is in the intake tube.)?
Old Jun 17, 2010 | 04:26 AM
TreasonAgainstCaesar's Avatar
TreasonAgainstCaesar is on a distinguished road
I'd agree with what has been said about cold air intakes so far.
As far as your mileage per tank, you might have quite a bit of gas left. Find out what size tank you have--I think it's in your owner's manual. Once the light comes on, fill up right away and find out how much you actually had left in your tank. On mine, the light comes on when I have just over 4 gallons left. Even at my crappy gas mileage that's over 60 miles more to go.
You ask if that's normal? I don't think there is such a thing as normal. Mileage varies depending on ambient temperature, 2wd or 4wd, 2 door or 4 door, driving style, city or highway driving, how hard you drive it, hills or flat, etc...
Old Jun 17, 2010 | 04:30 PM
apross44's Avatar
i was just asking because i was reading people getting 250 or so miles on their tank and I barely reach 220 with pushing it through my low fuel light. it usually is around 14.5 gallons for me to fill up. and with the cold air intake as I asked earlier can i make my own piping by just going lower in front of the mass air flow sensor? and if so how far down can I go?
Old Jun 18, 2010 | 02:14 PM
but if you have a 17 gallon tank, that's still 2.5 gallons which at 16 mpg is 40 miles left on the tank. So 220 + 40 = 260 miles per tank. And your tank might be larger than 17 gallons... I think the 2dr has a larger tank than my 4dr. is yours a 2dr or 4dr? I'm just saying, it might not be as bad as you think.
Yeah, you can make your own cold air intake. you can go as far down as there is room for it. you should remove the stock air box and use whatever room you have. you'd get better results from using a heat shield. I'd look at a pre-fab kit to get some ideas on how to go with it. If you need pictures of mine, let me know and I'll try to snap a few for ya.
Old Jun 18, 2010 | 08:47 PM
apross44's Avatar
i have a 4dr. yea snap a few pics of yours if you dont mind I just want to get an idea of how it is supposed to look. I was just worried if my map will throw a code to my computer.
Trying
Jun 2, 2013 10:02 PM
darklink
Jun 13, 2012 12:13 PM
Klturi421
Aug 2, 2011 07:21 PM
ussexplorer
Apr 11, 2010 06:53 PM
RCars2
Aug 4, 2007 11:29 PM
