'98 Blazer Timing chain replacement
Old Nov 4, 2009 | 03:04 PM
dpannazzo's Avatar
dpannazzo is on a distinguished road
As always thank you for your quick replies.
I managed to remove everything and am in the process of installing the new Crankshaft sprocket.
Any tips on the installation? I am afraid of trying to press the new one with the bolt and Socket (or piece of short piece cut pipe) as recomended because I am afriad of damaging the threads insinde the Crankshaft.
Thank you
Old Nov 4, 2009 | 03:19 PM
It is going on that tight?? I have done a few 4.3L timing chains (mostly for the tensioner tsb), and they did not go on all that tight that they could not be tapped on with a rubber mallet and a small piece of pipe.
Old Nov 6, 2009 | 03:08 PM
dpannazzo's Avatar
Hello all,
With your help I have installed the new timing chain with gears and all.
Now, Can anyone help with any tips or ticks installing the timing chain cover.
I have loosened the front 2 bolts on the oil pan as the book stated, though I tried to loosen the pan as a whole but could not because of the drive axle. I am having a hard time geting the bottom lip (inner & outer) of the cover over the gasket that is in place. There is very little clearance between the the gasket and the engine for the back bottom lip of the cover to slide in between.
Old Nov 6, 2009 | 04:30 PM
You will have to loosen the entire pan and then pry it down a bit.
Old Nov 6, 2009 | 04:37 PM
dpannazzo's Avatar
Thanks for you quick reply as always.
Old Dec 17, 2009 | 01:18 PM
chipjumper's Avatar
chipjumper is an unknown quantity at this point
How long did this whole job take you?
ComputerNerdBD
May 22, 2016 07:29 AM
ComputerNerdBD
Sep 6, 2011 12:05 AM
drblaze
18
Jun 22, 2011 01:58 PM
gabenton
Mar 26, 2010 08:23 AM
HomeGrown
Feb 10, 2010 04:19 PM
