98 Blazer Vibrates After Replacing Sway Bar Bushings
Old Dec 25, 2014 | 03:55 AM
teamrojas's Avatar
teamrojas is on a distinguished road
Default 98 Blazer Vibrates After Replacing Sway Bar Bushings
Hello All
My 1998 4WD 4dr Blazer recently needed me to replace the sway bar links.
After I replaced them , I was driving home and the truck started to vibrate.
I pulled over and everything looked OK. Is there a method on tightening
them?
Old Dec 25, 2014 | 09:34 AM
Sway bar links help reduce body roll on turns and can not cause a vibration. The bolts need to be torqued to 11 foot pounds.
What speed do you first start to notice the vibration? What speed is it most noticeable? Does it get worse or better if you increase speed?
Old Dec 25, 2014 | 12:06 PM
LeWhite's Avatar
The vibration that you feel is your new found connection with the road you are driving on. Enjoy your better responce to steering input and increased roll resistace. Happy Christmas!
Old Dec 25, 2014 | 04:29 PM
teamrojas's Avatar
It starts at about 10-15mph.
Old Dec 25, 2014 | 04:47 PM
Definitely not related to the sway bar.
Do you feel it, or hear it?
Could be a broken belt in a tire. Raise each tire off the ground and rotate it by hand while watching the tread. It should not waver inboard and outboard.
Old Dec 25, 2014 | 06:41 PM
rexazz2's Avatar
if you had the wheels off , check the wheel nuts
Old Dec 26, 2014 | 02:57 AM
teamrojas's Avatar
Cant hear it. It starts at about 10-15mph. I can let go of the steering and it moves back and forth. When I am driving at 30-40mph, I can turn the steering slightly to the left and the wobble goes away for a second.
Old Dec 26, 2014 | 07:17 AM
Classic symptom of a broken belt in a tire. If the vehicle moves back and forth, my guess is a front one. Might even be a bent wheel, but it sure sounds like a tire is not tracking true.
89GMCJames
Mar 23, 2011 11:02 AM
heypops
Nov 1, 2010 11:19 AM
BlazerLS
Suspension Tech
Sep 27, 2010 09:27 PM
bikernutgoofy
23
Mar 2, 2009 04:55 PM
adimepiece2
Oct 8, 2007 01:48 PM
