98 Blazer wont start??
Old Jan 4, 2016 | 07:14 PM
bethee222000's Avatar
bethee222000 is on a distinguished road
Default 98 Blazer wont start??
Car was running fine, then went to go somewhere and it fired up and as i drove out of the driveway it choked out and stalled. Had it towed to a shop and they said it was a fuel pump...They only replaced that and called and said my car was done..paid 650.00. When i picked it up it barely started,ran really rough and had alot of white smoke coming out tail pipe. I got it home and it hasnt started since. Turns over, but will not start. It has popped a few times. The shop told me I needed spark plugs because they were fouled from bad gas so i replaced those and they said my catalytic converter was plugged like a potato was stuck in it and that is why its not starting. They said if i replace the cat it will start. Is that true? Can a plugged cat make a car not start? I have checked relays,ignition modules, coil pack etc. Also for about a year i had a code come on saying egr valve. What could be causing it not to start?
dj00140
May 20, 2013 06:37 PM
JimmyBlaze541
May 2, 2013 10:00 AM
bobby099
15
Nov 7, 2012 07:29 PM
FreeTime
Sep 8, 2012 01:38 AM
jetsmy
Aug 1, 2008 10:10 PM
