98 Bravada No AC/Blower fan help!!!
Old Aug 22, 2016 | 07:51 AM
ambratton's Avatar
ambratton is on a distinguished road
Default 98 Bravada No AC/Blower fan help!!!
Alright guys, Ive got a 98 olds bravada with ATC. One day I went to get in my truck from work and went to turn on my A/C, I have no blower fan speed in either setting 1-5 or Auto. Ive checked all fuses and replaced the blower motor, blower motor resistor and still nothing. While switching the vent positions, all actuators work and i dont hear any vacum leaks.Any Ideas.
Old Aug 23, 2016 | 06:54 PM
ambratton's Avatar
Any ideas or suggestions!!
Old Aug 29, 2016 | 07:26 AM
ambratton's Avatar
Also upon further troubleshooting, I have 14 volts at the resistor and only 2.7 volts at the blower motor, while the truck is running. The wiring harness has no burn spots or cuts. I'm running out of options right now and need to get this fixed ASAP.
Old Aug 29, 2016 | 10:36 AM
rockp2's Avatar
I wonder if it may not be a problem with your ignition switch.
Old Aug 29, 2016 | 03:53 PM
ambratton's Avatar
Could be, but I have no idea where to start at. I have a Haynes manual and it doesn't even has a proper wiring diagram. So I'm going in blind. Thanks for the reply Rockp2. I will start looking in that area and see what I can find.
Old Aug 30, 2016 | 11:18 AM
rockp2's Avatar
One of the known issues on Blazers is faulty ignition switches. Sometimes the contacts are just dirty and can be cleaned. Many times it requires replacement of the switch (which is inside the steering column). The ignition switch controls power feed to many of your components and there may be some type of voltage drop going on there. That's more of a guess on my part since I am not super strong on electrical. I've attached a wiring diagram for a 98 Blazer... assuming the same for your Bravada.
If you go to alldatadiy.com you can buy a subscription for under $20 (annual) to an electronic version of the Technical Service Manual for your truck. Anytime I get another vehicle, I get a subscription for that vehicle as well as buy the actual manuals which can usually be found on ebay or Amazon for around $100 (+/- $50). Most of the time I like the hard copy version of the manuals, but the alldatadiy.com version has a very useful "Search" function and (depending on how you look at it) it's cheaper.
File Type: pdf
Old Aug 30, 2016 | 12:56 PM
ambratton's Avatar
Thanks for the info ROCKP2. anything will help me out right now. Again Thank you.
Old Sep 6, 2016 | 05:44 PM
stokedstephen's Avatar
stokedstephen is on a distinguished road
I seem to have the exact same problem with mine, and I replaced the same things. Did you find anything that fixed it?
Old Sep 6, 2016 | 06:02 PM
ambratton's Avatar
Stokedstephen, I have not yet found a solution. I'm still double checking wires going to the ignition switch. But if I do find one, I will let you know. It's mind boggling and frustrating.
Old Sep 7, 2016 | 08:35 PM
Well, this morning my blower kicked on after going over a little bump, stopped again, and then turned back on. It has stayed on, so I won't complain... but I'm just hoping it lasts!
