'98 Rear Disc Brakes
Old 03-31-2019, 11:51 AM
Glad to hear its fixed
Old 04-07-2019, 08:51 AM
jimspahr@msn.com's Avatar
I am also glad you were able to fix the problem. I wanted to add another common problem that can cause these same symptoms. The two caliper pins aka sliding pins will often stick due to corrosion, pitting, rust, 'no lube' and so on. Just cleaning them and lubricating them with a proper lube will often free up a 'sticking caliper'. If they are badly pitted, you can replace just the 2 pins and lube them. Check the cal. pins first to see if this is the problem and you could save money.
zman6988
10-14-2015 01:22 PM
ComputerNerdBD
03-14-2013 12:44 AM
lombard
03-28-2011 06:23 PM
toaks1
16
01-20-2010 08:12 AM
Acer2428
07-13-2006 11:52 PM
Quick Reply: '98 Rear Disc Brakes
