'98 Rear Disc Brakes
Old Mar 31, 2019 | 11:51 AM
Glad to hear its fixed
Old Apr 7, 2019 | 08:51 AM
jimspahr@msn.com's Avatar
I am also glad you were able to fix the problem. I wanted to add another common problem that can cause these same symptoms. The two caliper pins aka sliding pins will often stick due to corrosion, pitting, rust, 'no lube' and so on. Just cleaning them and lubricating them with a proper lube will often free up a 'sticking caliper'. If they are badly pitted, you can replace just the 2 pins and lube them. Check the cal. pins first to see if this is the problem and you could save money.
zman6988
Oct 14, 2015 01:22 PM
ComputerNerdBD
Mar 14, 2013 12:44 AM
lombard
Mar 28, 2011 06:23 PM
toaks1
16
Jan 20, 2010 08:12 AM
Acer2428
Jul 13, 2006 11:52 PM
