99 4.3 slight intermediate skip/miss
my 99 4.3 was running perfect no skipping missing no nothing no cel and on Friday it blew a lower intake manifold gasket, I tore it apart and replace the lower intake manifold gasket put it all back together and it runs perfect again other than a small skip/ miss but it doesn't do it all the time any thoughts on that?
new plugs right after fixing, recent cap,rotor,wires,iac,tps
If it didn't have it before, it 'most likely' is something you did/touched. Goo back over all you did....hoses tight, not cracked (a carb cleaner may help with this)..all electrical is plugged in properly (ie plug wires seated to cap tightly)..good luck...Jerry
Yes, agreed
With the ignition off: Using a ratchet and socket on the crankshaft center bolt, manually rotate the crankshaft ONLY clockwise until the timing marks are aligned like this:
AND the rotor is within a few degrees of this:
Remove the distributor and install it so the rotor points to the #6, (or very close) on the distributor housing when the distributor is fully seated against the intake manifold. DO NOT rotate the crankshaft while the distributor is removed.
