99 4.3 vortec p0300 white smoke
Old Dec 15, 2012 | 10:12 PM
leac0071's Avatar
leac0071 is on a distinguished road
Default 99 4.3 vortec p0300 white smoke
Hi I'm new to the forum. After exhausting the search feature I've decided it's time to post. I recently replaced the head gaskets on a 99 blazer that has been sitting for 3 months with coolant/oil mix in the crank case. It started up and drove great for a while (2days), but would die while making a turn or braking. It has since become hard to start and has a P0300 code. When it does fire up it creates a lot of white smoke which doesn't smell like coolant. The coolant level has also remained unchanged. The fuel pressure was low (x<60psi) so the pump has been changed. Now the pressure passes prime and watch for 5-10min test. New cap, rotor, plugs and wires have also been installed.
Some additional freeze frame info from a scan tool is:
STFT b1 50%
STFT b2 33.5%
Map (mmHg) 15.6
TPS (not open) 0%
RPM 611
If a high STFT is a lean condition, could that mean the injectors are clogged/leaking?
My next thought after searching the forums was to look into the spider assembly unless someone has a better suggestion.
Thanks you for reading,
Glenn
92blazer92
Jan 25, 2010 12:46 AM
Sparky
Oct 4, 2008 07:16 PM
vernoninmd
Feb 24, 2008 11:52 AM
apoch
Feb 13, 2008 11:47 AM
SniperX13
Jun 11, 2006 03:00 AM
