99 blazer 4hi does not stop blinking when trying to engage 4wd.
Old Dec 14, 2004 | 05:17 PM
tambo's Avatar
tambo is an unknown quantity at this point
Default 99 blazer 4hi does not stop blinking when trying to engage 4wd.
I have a 99 Blazer that when I press the 4hi button, it just blinks, and does not engage when trying to go to 4wd. Can someone please tell me what I should be looking for?
Thanks for any help in advance.
Old Dec 16, 2004 | 05:33 AM
01xtreme's Avatar
01xtreme is an unknown quantity at this point
Default RE: 99 blazer 4hi does not stop blinking when trying to engage 4wd.
To switch to 4WD, you have to hit the button, and drive SLOW...2-5 mph slow. That should pretty much do the trick. Repreat process to switch to the other modes.
Old Jan 6, 2005 | 01:08 PM
Grkblazer's Avatar
Grkblazer is an unknown quantity at this point
thats not the problem. the problem is the cable that goes to the front axle back to the vacuum has rusted and got stuck.. does your battery leak? common problem, happened on my 99 too.
jim
Old Feb 26, 2005 | 09:15 PM
astro's Avatar
astro is an unknown quantity at this point
I had the exact same problem with my 98 and it was the encoder motor. The mechanic told me to use 4x4 more often or this might happen again. It cost aruond $225 to fix.
Old Feb 27, 2005 | 12:26 PM
Fat Timmy's Avatar
Fat Timmy is an unknown quantity at this point
my '99 Zr2 had the cable problem. the wiring harness had corroded from (yes) battery acid and wasnt making contact. it was a bitch for me, i had to take it to the dealer to get it figured out (thanks to extended warranty). I definitely dont have the problem of lack of use. I've got mine in 4x4 at least once a month. Use it!
Old Mar 4, 2005 | 05:44 PM
BLAZIN's Avatar
BLAZIN is an unknown quantity at this point
I have the same problem with mine, it clicks into the 4hi but it doesn't engage i know cause i got stuck in the snow a few days ago, any suggestions? we changed to decoder motor back in 2002 and we always use the 4x4, hell i used it back during christmas and it worked like a charm.
Mike_Williams7
Feb 10, 2015 07:29 AM
jspafford
Jun 10, 2009 04:51 PM
sceb
Feb 6, 2009 09:37 AM
hgreg
Sep 5, 2008 11:07 AM
wick001
Dec 2, 2006 10:05 PM
