99 Blazer 4WD LT Instrument Cluster ?
Old Jun 9, 2013 | 04:13 PM
twenty4sux's Avatar
twenty4sux is on a distinguished road
Default 99 Blazer 4WD LT Instrument Cluster ?
My 99 Blazer has instrument cluster problems. Tach jumps randomly, lights(brake, ABS, low fuel, all of them) flash randomly, gas guage stays on 1/4 tank. About the only thing still working fairly correctly is the speedometer, which at times is about 10MPH off, verified by my GPS. everything is random. Any ideas? I got a ECM and cluster from junk yard but haven't tried replacing either yet. I found out that I have to have the ECM programmed before installing, so guess that was a waste. Also the odometer no longer works. Lights up once in a while, but isn't even close to actual mileage. One day it was all zeros and was going up as I drove. Best guess approximately 200,000 miles.
Thanks in advance for your input,
William
Old Jun 9, 2013 | 06:23 PM
The PCM, BCM, TCCM, and EBCM all gather data and share the serial data through ClassII communications. The BCM ultimately controls the instrument cluster. You'll need a bi-directional scan tool capable of accessing and commanding functions of the BCM to troubleshoot the problem.
Old Jun 10, 2013 | 02:52 PM
twenty4sux's Avatar
Would this tool connect to the diagnostic connector to communicate? I have taken it to Autozone and Advance and neither one can communicate with it
Old Jun 10, 2013 | 03:04 PM
Yes, the scan tool connects to the data link connector under the dash. The el cheapo scan tools that the auto parts stores use can NOT access the BCM. It must be a bi-directional scan tool capable of accessing and commanding functions in the BCM. Ebay usually has some decent used ones starting around $2K. A GM dealer can diagnose the problem for around $100.
2manybroke
Nov 26, 2011 06:18 AM
Polygraph
Sep 15, 2011 01:27 AM
n9ktw
Apr 20, 2011 06:58 AM
elementalnature
Mar 24, 2008 05:31 PM
error_401
Mar 17, 2008 06:39 PM
