99 blazer bad fuel mileage
Old Dec 28, 2011 | 11:41 AM
adam10's Avatar
adam10 is on a distinguished road
Default 99 blazer bad fuel mileage
my wifes 99 blazer has started getting really bad fuel mileage.about 7.8 to 8.5 it fluctuates.she uses it to deliver mail and she used to get 11.5. heres the list of things i tried so far.new fuel filter,new cap and rotor plugs and wires.plugs looked clean no evidence of running rich.it runs great.heres one thing i dont know if it would affect it.in the hot summer 85 degrees and up once in a while it will throw a po452 evap emmissions control system pressure sensor/switch low input.if you pop the gas cap or let it sit overnite it goes away.its done this since new fuel pump but gas mileage just started going downhill this year.like i said it runs great.checked for fuel leaks.really lost on this one any help would be appreciated.thanks in advance
Old May 19, 2013 | 10:41 PM
teklife25's Avatar
teklife25 is on a distinguished road
Were you able to find a solution to your decrease in mpg? I have a similiar problem with my 99 after replacing the fp.
Old May 20, 2013 | 08:04 PM
adam10's Avatar
I ran some sea foam through it every month.half bottle to a tank of gas.it helps but not a real good answer.
Old May 20, 2013 | 08:06 PM
adam10's Avatar
I've put it on a scanner and drove it everything checks out normal.
Old May 20, 2013 | 09:21 PM
cleburne red's Avatar
If your scanner can show live data, check the fuel trims. That will let you know if it's actually running rich, or what.
Maybe you've got an O2 sensor or two getting lazy, but not bad enough to throw a code?
Heck, maybe they're sneaking in more ethanol into your fuel! That won't help mileage any,lol!
Old May 21, 2013 | 06:10 PM
adam10's Avatar
yes it was a live scanner.everything was in specs.local garage ran it for me while I was there
Old May 21, 2013 | 06:48 PM
scottl1346's Avatar
scottl1346 is on a distinguished road
how are the injectors?
Old May 22, 2013 | 03:05 PM
adam10's Avatar
been in there for 150,000 miles
Old May 22, 2013 | 09:19 PM
scottl1346's Avatar
might be time to check them out
bigdaddyjanks
Jun 6, 2011 11:43 PM
begrdnr
May 17, 2011 02:42 PM
stevenson_ltdan
Jan 23, 2008 04:15 AM
turbo99397
Nov 25, 2007 01:49 PM
drwalker88
Feb 16, 2007 01:18 AM
