99 Blazer Heater Blower Issue
Old Mar 7, 2011 | 06:16 PM
bandadeboer's Avatar
bandadeboer is on a distinguished road
Default 99 Blazer Heater Blower Issue
My truck has an awesome heater but the sucky thing is that it doesn't blow on the floor... where I like it best. When I put it on the floor setting or the floor/defrost setting, it just blows defrost (windshield). Anybody know why this happens or how to fix it?
Old Mar 7, 2011 | 08:07 PM
vegie_2's Avatar
vegie_2 is on a distinguished road
check all vacuum hoses under hood would be a good start
Old Mar 7, 2011 | 08:23 PM
simple_2_me's Avatar
simple_2_me is on a distinguished road
If you are changing from the dash to defrost then it's most likely the selector switch or one of the vacuum actuators that is bad.
Old Mar 7, 2011 | 09:51 PM
warthogdriver's Avatar
had this happen to me, it is a small plastic damper in the plenum just behind the ash tray, they brake at the neck and then will not rotate into position. there is an easy way to fix this.
this thread covers this.
https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/98-blazer-no-floor-heat-17808/
just recently someone on here fixed this without cutting, i believe they removed the center console on the floor and then the small plastic channels that connect to the ducts on the floor and was able to put there hand up in the ducts and swap out the part.
do a search on no floor heat, this seems to happen alot to our rides...plastic gets old and brittle then snaps in winter weather.
good luck.
maxvamp
Oct 31, 2020 08:19 AM
unpredictable1
24
Jan 10, 2016 10:22 AM
comandoed
Nov 8, 2013 11:00 AM
aztcwrior25otvws25
May 23, 2011 08:16 PM
aspenpup
Jul 3, 2005 06:56 AM
