99 blazer hesitates after start up..HELP!!!!
Definitely not the best way to clean a MAF sensor. Read this thread.
. A lot of people have successfully used brake cleaner or other chemicals..I believe in using something made for the job. Consider buying 2 can..that's from the thread you recommended
Last edited by swartlkk; 06-07-2011 at 06:38 AM. Reason: *Combining Consecutive Posts* - Please use the EDIT feature to add additional information to your post if another member yet to respond.
Hey it worked..and saved me atleast $100...and as long as its dry before you reinstall it what's it matter?
Cleaning it yourself is what saved you the $$, not the use of an improper cleaning fluid for the job so you can get off the soap box. You could have easily wasted your time and money using brake cleaner.
Get off the soap box. .lmao it worked n that's all that mattere..worst case scenario I have to buy a new sensor..n you can get off the thread..it was a convo between me n another user and I told him what I did to clean it..I thought that's what forums were for..advice, ideas and discussion..get of my back the forum is better off without you..***** YOU. I'm goin back to ford
Well, good-bye and best of luck in life. Oh, BTW, your membership here is revoked and you are banned from the Forum due to your attitude, language, and ignorance.
What works for you once might cause someone else to ruin an otherwise good sensor, wasting their time and often hard earned money. How does that make sense? I stated why brake cleaner is a bad idea. That IS what forums are for, to provide the absolute best information so that others can make the proper decisions in how to work on their vehicles. Sorry that you couldn't accept that you were wrong in using what you used and had to be belligerent about it. And isn't this a DISCUSSION??? You make no sense what so ever. You even stated that if there was something specifically made for the job, you would use it...
Regardless, Rich has already taken the action to remove you and your childish behavior/attitude from our humble forum. Good day.
hotrodsbyg
07-23-2019 01:40 PM
robbi_carter
07-13-2010 05:20 PM
robbi_carter
04-30-2010 10:15 AM
