99 Blazer - The ol' Brake light problem
Old Jan 12, 2008 | 07:14 PM
xunzi's Avatar
xunzi is an unknown quantity at this point
Default 99 Blazer - The ol' Brake light problem
Hi all,
My 99 Blazer had the ol' Brake light problem where the CHMSL would work but the side brake lights would not. Checked all fuses and came to the conclusion that it was the multi-function switch (as is so common).
Installed a new multi-function switch and now have a new problem: When the DRL/headlights are on - the brake lights are always on. With the DRL/headlights off the brakes still don't work. Sigh.
Can anyone point me in the right direction in regards to troubleshooting/diagnosing.
Thanks.
Old Jan 14, 2008 | 08:05 PM
Kordog's Avatar
Kordog is an unknown quantity at this point
Default RE: 99 Blazer - The ol' Brake light problem
Sounds like you may have gotten a bad switch, that would be the only place those two circuits would even remotely come in contact with each other.
Old Jan 15, 2008 | 10:02 AM
xunzi's Avatar
Thanks, I was dreading that answer
But hey, at least I've had a trial run at getting to the effin' switch.
Old Feb 18, 2008 | 06:48 PM
DLFrederick's Avatar
DLFrederick is an unknown quantity at this point
Where if that "Multifunction" switch?
Old Feb 18, 2008 | 08:58 PM
The multifunction switch is the turn signal stalk. Located on the passenger side of the steering column. Also controls headlight hi/lo, cruise, and windsheild wiper/washer.
ssboy81
Mar 15, 2012 07:58 PM
Doggpool
May 24, 2011 08:17 PM
beastbandit92
Aug 13, 2010 08:24 PM
SCBlazer96
Apr 16, 2010 08:39 PM
xderkax
Jan 14, 2010 11:38 PM
