Brake-dash light problem-Light comes on stays on
Old May 20, 2011 | 10:43 AM
Doggpool's Avatar
Doggpool is on a distinguished road
Default Brake-dash light problem-Light comes on stays on
I have a 1990 Chevy Blazer K5 350 4-wheel drive. I am having problems with my brake dash light coming on after reaching 35mph and staying on till I turn blazer off. I have changed the brake switch and the brake computer, but I am still having the same issue. My actual brake lights work fine. Just very annoyed that the dash light will not go off. Any suggestions??
Old May 20, 2011 | 09:09 PM
Z71_Guy's Avatar
Z71_Guy is on a distinguished road
on my 85 i replaced the rear brake lines (they were leaking) and the wheel cylinders and the light went off. not sure why but it worked and was cheep.
Old May 23, 2011 | 01:29 AM
THePaRaSiTE5771's Avatar
THePaRaSiTE5771 is on a distinguished road
As Z71Guy said, replacing the wheel cylinders might fix your issue. Happened on my 1990 Blazer and the light went out after I replaced them.
Old May 23, 2011 | 01:41 AM
Cidium's Avatar
Cidium is on a distinguished road
From what I understand there are 2 conditions for the brake light on the dash to come on. First one being obvious, the parking brake has been engaged, second, there is a low pressure condition in the ABS system. Not sure what 35 mph has to with it, but if you do have ABS then I would say there is something going on with the pump/ABS unit. I would think if you are having an ABS issue the ABS dash light would be on. It's always possible there has been an ABS code generated but the dash bulb isn't working, burnt out. As for the parking brake, I just don't see it being the reason , unless something totally freaky is happening on the E-brake switch. But like you said that has been replaced.
Old May 23, 2011 | 08:42 AM
Doggpool's Avatar
have a k5 blazer and don't think they had a abs light. not leaking any fluid but will go and check wheel cylinders to see if they are bad
Old May 24, 2011 | 08:17 PM
Doggpool,
Let us know what you find.
mustardrocket
Jan 4, 2015 06:15 PM
armydad71
15
Dec 8, 2011 06:42 AM
BIG SURF
Mar 19, 2009 03:18 PM
pilgrim
Feb 4, 2007 04:28 AM
