99 blazer start up issues
Old Oct 8, 2014 | 12:51 PM
xpsychox's Avatar
xpsychox is on a distinguished road
Default 99 blazer start up issues
My wife's 99 blazer is having start up issues.. Turn the key and u can hear starter etc and u can her it start to fire let go of key to let it run. It dies, do it again and its fine.. Before I posted this I heard her turn the key and hold it and does samethinf just held it and wouldn't fully start. Any ideas?
Things I've done:
Spark plug wires
Distributor cap
And rotor
New rotors and breaks for front
Turned down rear rotors and breaks
Have NOT done plugs yet..been meaning to.
Known issues thus far:
altinator is starting to go out (still charges just grease is gone)
same with ac compressor
O2 sensor driver side after cat. Is bad
Upper ball joint driver side
Sway bar link pass side
Rear end slaming into gear..thanks!
Old Oct 8, 2014 | 02:38 PM
These things are real fussy when it comes to tune up parts, they all need to be AC Delco, especially the spark plugs, (41-993) distributor cap, (D328A) & rotor, (D465). The spark plug wires need to be a good quality name brand, (AC Delco, Belden, Autolite, etc) NOT a store brand, (Duralast etc). These are all basic items that must be correct if you want the engine to perform properly.
Next step is check fuel pressure and leakdown at the service port next to the distributor. Most auto parts stores rent/loan them for free, and sell the for around $40. When you have one available, let us know and we can guide you through the test procedures, (very simple).
Old Oct 8, 2014 | 04:53 PM
xpsychox's Avatar
Fuel pressure gauge is $100 to rent.. I don't know what the leakdown is.
Old Oct 8, 2014 | 07:59 PM
Fuel pressure and leakdown is critical on this engine, gotta be in spec or you'll have problems.
Old Oct 8, 2014 | 11:34 PM
xpsychox's Avatar
Again..I don't know what leakdown is...
Old Oct 9, 2014 | 02:53 PM
With the ignition in the run position, engine off, the fuel pump should be activated for about 2 seconds and then shut off. The pressure while the pump is running should be 60psi to 66psi. The pressure must remain above 55psi for at least 10 minutes after the pump shuts off. The amount that the pressure drops is called "leakdown".
Old Oct 9, 2014 | 08:21 PM
xpsychox's Avatar
Ahh..OK... Guess my day is dine then..learned something new..lol I'll have to wait till this weekend to do this..any chance u have a diagram/pic if where to connect it at?
Edit: also, would outside temp make a difference? Meaning like 50s or 80s?
Old Oct 9, 2014 | 08:30 PM
burned's Avatar
burned is on a distinguished road
#7 in the diagram
Old Oct 9, 2014 | 11:20 PM
xpsychox's Avatar
Originally Posted by burned
#7 in the diagram
Well..looks like I know what I'm doing this weekend.. Would ave never guessed it was there. And to follow up my last ?.. Would outside temp affect the start up of what its been doing (I know too cold would hurt battery etc)
daemeon2
Jan 6, 2013 04:06 PM
99slobra
Jan 3, 2013 05:02 PM
cruukedeye
Jun 4, 2011 06:49 PM
nomechanic
Jul 14, 2009 07:53 AM
HowlingX
Jan 18, 2009 01:30 PM
