99 Blazer steering wheel problems??
Old Oct 24, 2009 | 02:31 PM
okstud's Avatar
okstud is an unknown quantity at this point
Default 99 Blazer steering wheel problems??
My problem is mostly noticeable on the highway. The steering wheel has a lot of play if i turn it to the right and feel very loose, and when i turn it left it has very little play and is tight. When i do move the steering wheel it doest go back to the original position and sometimes the steering wheel will start to shake. The vehicle doesnt seem to have bad alignment. Maybe it just needs to be balanced to fix the shaking problem but i am kinda worried about the steering wheel part. Any help would be greatly appreciated! Thanks
Old Oct 24, 2009 | 03:37 PM
I would inspect the steering components looking for play. Have a good look at the pitman and idler arms. A bad idler arm can cause symptoms similar to what you describe.
Old Oct 24, 2009 | 09:29 PM
okstud's Avatar
I recently had the pitman and idler arms replaced. Could it be the tie rod ends? They are part of the steering components.
ctyler
Aug 25, 2020 04:06 PM
litterbug
Oct 19, 2011 07:50 AM
Parilio
Sep 21, 2011 06:56 AM
caseroj
Oct 20, 2010 08:10 AM
Blazertrish66
Apr 29, 2008 07:54 PM
