'99 Blazer stuck in 4wd
Old Dec 15, 2006 | 05:26 PM
nytewrkr's Avatar
nytewrkr is an unknown quantity at this point
Default '99 Blazer stuck in 4wd
'99 Blazer with electronic 4wd switches on dash stuck in 4wd after switching it in one day.
I've replaced the actuator and it still is stuck. I am getting a selenoid clicking sound under the glove box. What is making that?
What can I try next?
Thanx.
Old Dec 15, 2006 | 05:43 PM
20Blazer00's Avatar
Default RE: '99 Blazer stuck in 4wd
There is an electronic actuator on the transfer case close to the front driveline output shaft, it has wires hooked to it. This controls 4HI to 4LO operation.
There is also a vacuum switch on the transfer case with three vacuum lines coming out the top this also has control of 2HI - 4HI engaging... if it is leaking or the seal is broken then it will suck up transfer case fluid. There is a newer designed switch available from the dealer, under $20??
Old Dec 15, 2006 | 07:25 PM
hillbillyinOhio's Avatar
did you check the 4wd fuse in the panel
Old Dec 15, 2006 | 11:41 PM
92teg92's Avatar
92teg92 is an unknown quantity at this point
im having this same problem, when i push the 2HI button it will click as if it is trying to go back into 2 wheel drive, but it ends up staying in 4HI. i have been able to get it to come out of 4 wheel by going up my driveway (a steap incline) moderatly fast and jolting the truck arround while pushing the 2HI button and it switches back in...
stingray74
Mar 5, 2015 08:27 PM
mr.vls
May 4, 2013 03:45 AM
Havensk
Jul 25, 2010 08:16 PM
aspenrebel
Dec 12, 2007 05:52 PM
bcmaxx
May 8, 2006 06:59 PM
