99 blazer transmission question
Old Mar 16, 2010 | 09:43 AM
Pobey's Avatar
Pobey is on a distinguished road
Default 99 blazer transmission question
Well at the moment it's working but it doesn't always like to shift. I was just wondering ballpark how much it would run to have the transmission rebuilt
Old Mar 16, 2010 | 10:16 AM
That is a somewhat loaded question as it depends on the damage and your location. Around here, if you are dropping the truck off someplace, expect $1500-$1800 for a rebuild. If you are going to take the transmission out, well, the cost will go down. Call around to local shops to get an idea of what they would charge for a general rebuild.
Old Mar 16, 2010 | 07:04 PM
1997 red blazer's Avatar
1997 red blazer is on a distinguished road
Question, How many miles are on the Transmission? Has it every been serviced ? I have had Good Luck with High Mileage Trans with a Fluid & filter change and Add the Lucas Trans Additive. I am not one for Additives, but has worked for me. It is Not a repair if it is Totality worn out slipping in all gears, but Helps(Band-aid) with the shifts and worn Clutches in the Transmission, so as to maybe you could get some more miles out of it before a total Rebuild . Maybe it would work for you? Good Luck T.J.
Old Mar 16, 2010 | 07:26 PM
LuvMyTJ's Avatar
I'm with Kyle on this one. The tranny was done in my 4x4 Blazer a couple years ago for about $1600. Prepare to pay. If you have a 2 wheel drive, it should be slightly less than a 4x4.
Don't feel to bad though... the rebuilt tranny in the AWD Mercedes Benz I just got was replaced a month ago for the princely sum of $3000!
Old Mar 16, 2010 | 10:23 PM
1998MSO's Avatar
1998MSO is on a distinguished road
Just a thought, but is your check engine light on or engine not running well? The reason I ask is I can't tell you how many times I've heard of transmission issues that are actually an engine performance issue. The computer on your vehicle controls the shifting and if it's in "open loop" mode or getting bad data it can affect the transmission. How many miles you have on the Blazer?
Old Mar 27, 2010 | 09:26 AM
Pobey's Avatar
Well it's a 99 and it's got 234000 on it not sure if it's been rebuilt before but then again I don't know much about cars I bought this so I would have something to start learning on
Old Mar 27, 2010 | 11:19 AM
LuvMyTJ's Avatar
So what your saying is it's just gotten broken in?
c0a8l0v6i8n9
Feb 21, 2011 06:04 PM
UndeadPrincess
Jan 28, 2011 11:25 PM
TimsR1
Nov 15, 2010 08:53 PM
GloryImSaved
Jul 17, 2009 09:05 PM
sfesenko
Dec 12, 2008 10:03 AM
