99 Blazer Will Not Start
I'm new to the forum and this may have already been discussed. I have a 1999 Blazer that was running a little rough. I replaced the distributor pickup module and now it will not run. It will turn over and act like it is back firing but will not start. I tried putting the old part back on and it still will not run. Any help is greatly appreciated.
Thanks,
Mike
Thanks,
Mike
I did not remove the distributor during the installation. I removed the distributor cap, then rotor, then the module. I am not sure what the piece is called but it bolts to the inside of the distributor and has three wires running to it. After it failed to start i checked the wires to make sure they were on correctly. The back firing was due to the mix up of plug two and four, I also changed the ignition module after posting the problem here.
Replaced the fuel pump, what I thought was the problem but still will not start. It turns but nothing, Checked fuses, battery and still nothing. Need ideas of what it could be. Starter almost new, distributer cap and rotor new.
stschuyler25
Nov 21, 2010 09:34 AM
wayland
Dec 9, 2009 12:38 PM
blazerJim1701
Jul 26, 2009 09:18 PM
Larhatch60y
Nov 8, 2007 01:05 AM
apekim
Jun 30, 2006 10:38 AM
