'99 Blazer Won't Start
Old Jan 21, 2010 | 05:58 PM
BEN53's Avatar
BEN53 is on a distinguished road
Default '99 Blazer Won't Start
Ichanged a engine in a 99 blazer,same engine 4.3 .you turn the key to start and it does nothing,check all wires and they are all hooked up.cant figure it out any help would be so great
Old Jan 28, 2010 | 05:50 AM
awe341's Avatar
awe341 is on a distinguished road
There could be a number of problems that pop up after a motor swap and it can be difficult to pinpoint without being there. The more information that you can give the better.
Do your dash lights and headlights ect come on when you turn the key?
If they do, do they dim when you try to crank the engine over?
Any noises at all from the truck when you turn the key or when you try to crank it? For example you should hear the fuel pump kick in as well as a few servo type motors such as the IAC kicking in.
Old Jan 28, 2010 | 06:09 AM
samuknow's Avatar
samuknow is an unknown quantity at this point
When I swapped my engine my friend hooked up the starter wrong and then broke the small signal wire. If nothing is happening and all the lights are coming on, start there.
andrewrj
May 6, 2012 07:28 PM
princered72
Sep 13, 2011 10:36 AM
Dark Rider
Aug 8, 2010 11:57 PM
1BSBAKER
Aug 11, 2009 10:54 AM
Irish10Hockey
Nov 13, 2008 02:48 PM
