99 Blazer won't start
Old Jan 25, 2011 | 06:59 PM
armyguy's Avatar
armyguy is on a distinguished road
Default 99 Blazer won't start
I have a 99 Blazer that won't turn over. It has gas, battery is good, and alterntor is good. My father in law suggested that it might be my Distributor and Rotor, and told me to check it by taking spark plug wire on drive side out and putting it to a new plug to see if I get a spark. any suggestions to what it might be if this isn't the problem. I am affraid it might be my fuel pump. I am not car/truck smart what so ever, any suggestions would be greatlly appreciated.
Chris
Old Jan 25, 2011 | 07:46 PM
mr.vls's Avatar
It is either spark, fuel or timing. If you have spark then I would check fuel pressure at the test port. You need about 55 psi for it to run. It should hold pressure after key is off. Having gas in the tank or even at the test port if it is not at the right pressure it will not run.
Old Jan 26, 2011 | 04:01 PM
mykeboy01's Avatar
mykeboy01 is on a distinguished road
Try starting it in Neutral...just a hunch
andrewrj
May 6, 2012 07:28 PM
princered72
Sep 13, 2011 10:36 AM
Dark Rider
Aug 8, 2010 11:57 PM
1BSBAKER
Aug 11, 2009 10:54 AM
Irish10Hockey
Nov 13, 2008 02:48 PM
