99 Bravada-door jamb switch
Old Nov 12, 2010 | 06:38 AM
h2opro's Avatar
h2opro is on a distinguished road
Default 99 Bravada-door jamb switch
Greetings, first post in here. 99 Bravada- interior lights stay on all the time unless overrode with dome override switch. Saw in some other forums that jamb switch on side of dash does nothing, literally. Pulled mine out and saw its connected to nothing. So, its in the door. Is this switch in the handle assembly? Any other advice?
Held in the door plungers in the back doors manually, didn't make a difference, assume its in the front. Thanks.
Old Nov 12, 2010 | 06:46 AM
The switches are part of the latch. You have to pull the door panel, peal back the weather deflector, and then disconnect the electrical connection at the latch itself.
I would recommend pulling all of the switches and taping the connection so that it A) can't fall back inside the pillars/tailgate/etc and B) doesn't ground out completing the circuit and keeping the light on.
Old Nov 12, 2010 | 06:51 AM
h2opro's Avatar
Thanks for quick reply!
I believe the back door plungers do actually function in the jamb, I don't think the lights came on when the back doors were opened, but don't remember. Guess I will start with the front.
Old Nov 12, 2010 | 09:04 AM
h2opro's Avatar
Do you know of the part number for this in the front door? Not having any luck finding it so far. Thanks.
Dadatone
Nov 8, 2021 09:34 AM
beardface
Jan 7, 2014 04:16 PM
beardface
Jan 7, 2014 03:34 PM
tbirdguy
Feb 18, 2013 10:53 PM
tilley101
Jan 26, 2008 10:02 PM
