99 chevy blazer AC recirculation
Old Aug 25, 2020 | 10:37 AM
chroniclifter's Avatar
chroniclifter is on a distinguished road
Default 99 chevy blazer AC recirculation
Hey everyone. New here so i will do my best to state my issue clearly. I have a 99 chevy blazer 4.3 liter 2 wheel drive 370k miles. My AC only seems to be drawing from outside air. I figure it is one of the actuators but cant find anything definitive online. So i figured "Hey, why not ask the guys who have Blazers as well !!" I know 1 or more of the actuators is bad because it will not shift from vent to floor or to defrost. But hey, at 370k miles as long as the vents work i am fine with that. But with outside air, the vent output is limited. Re-circ air i hope will have more output. And i do not have a recirc air button on my system. I have read that the "MaxAC" fills that role. But AC or MaxAC has no difference in output. Thoughts??
Old Aug 25, 2020 | 01:37 PM
The blend doors are vacuum-actuated. Make sure your vacuum hoses are good and you don't have any leaks.
Old Aug 25, 2020 | 05:45 PM
Dityo on the vacuum hoses. They tend to rot and then leak.
Old Aug 26, 2020 | 09:36 AM
LannyL81's Avatar
Take a look at the actuators behind the glove box door; drop the door down and there are two actuators.
Also take a look at the two that are towards the center above the accelerator pedal. Check to see if the white plastic piece has broken.
There is also a "valve" that is inside the ducting called the defrost valve. Common for it to break. This is what shifts air flow from floor to dash. Search here, you will find pictures.
PhantomDiesel
Mar 20, 2020 05:21 PM
djsgarrett
Jul 8, 2015 04:30 PM
rtk3
Aug 26, 2014 02:46 PM
elwaykid
Jul 28, 2014 12:51 PM
jagblazer01
Oct 16, 2009 06:57 PM
