99 Jimmy brakes locking up
Old Feb 1, 2024 | 09:23 AM
ItsmeErnestT's Avatar
ItsmeErnestT is on a distinguished road
Default 99 Jimmy brakes locking up
Hi. I am new here, but I really need some help. Please forgive me if I don't use the correct terminology as I have limited experience in this. I've had an ongoing problem for a number of months now without remedy.
All four wheels brakes lock up while moving. It starts out ok, but when I apply the brakes initially and release, all four start locking up. It seems all four calipers start grabbing without release til the car comes to a stop. This happens without pressing the brake pedal after the first press and release. It is also accompanied with a roaring that sounds to come from front driver. Once I park it, smoke is rolling from all four and the rotors are almost glowing.
I've replaced the brake booster, master cylinder and reservoir, abs module(but that looks to be a junk yard part?), and front driver caliper and brake line. After that, the mechanic power bled the system. I was then told it was fixed, but it in fact was NOT fixed. It continues to do the same thing. I can crack the lines at the block and release pressure to be able to move again briefly as long as I don't have to apply the brakes. Yesterday I removed the abs fuse as I read it disables the abs, but the problem still continued. Im ready to give up, but I need this vehicle badly. Any help is greatly appreciated.
Old Feb 2, 2024 | 11:27 PM
This is a shot in the dark, but are the caliper guide rods seized or very corroded? I had my rear caliper guide rods seize on me when they were exposed to salt water when I was retrieving a boat.
Old Feb 4, 2024 | 02:19 AM
Groundlevellouisiana's Avatar
Groundlevellouisiana is on a distinguished road
if the guide pins don’t have brake grease on them they will stick causing the caliper to grab like that
Old Feb 4, 2024 | 11:02 AM
GeorgeLG's Avatar
If breaking the hydraulic line releases the brake at the wheel then the problem is not at the caliper.
George
Old Feb 4, 2024 | 11:17 AM
GeorgeLG's Avatar
Assuming that the master cylinder and ABS module replacements were done correctly then:
https://www.google.com/search?q=brak...oMZBQ5TUM,st:0
If not that then look at the brake pedal linkage
George
Old Feb 4, 2024 | 12:53 PM
George
George
. What George said!
Blazer222
Feb 20, 2024 12:46 PM
spiderlake
Jan 30, 2021 01:20 AM
BlazinZR
Nov 9, 2019 12:44 AM
Poor Man
Nov 2, 2013 07:06 PM
will
Jul 26, 2009 04:11 PM
