99 S-10 Evaporator Replacement
Old Apr 19, 2010 | 05:11 PM
mattj3773's Avatar
mattj3773 is on a distinguished road
Default 99 S-10 Evaporator Replacement
New to the forum, and I have not been able to find a thread with the details I am looking for. So, to start, my blazer has been leaking refrigerant from the A/C system slowly for a while now. I had dye put in and the leak is originating from the compressor. I decided to put in a new one rather than mess around with a rebuild. Also, chose to replace the accumulator/dryer and orifice tube because they have never been changed and the truck has 230,000+ miles on it. While disassembling the system, I came to find out the evaporator needs to be replaced as well.
What I am looking for is an idea of the easiest way to remove it the evaporator. If anyone has a diagram with all the bolts that hold the housing together, that would be fantastic. Also, any advice on the simplest removal method would be greatly appreciated too.
Thanks,
Matt
Old Apr 20, 2010 | 09:25 AM
RaginInferno's Avatar
RaginInferno is on a distinguished road
This is my daughters Blazer...
See that box with the grey foam? The Evaporator Core is inside that box. Plan of removing the entire dashboard assy. as well as the underhood components
P.S. Change you heater core while your there!
Eric D
40
Aug 12, 2020 05:04 PM
ComputerNerdBD
Aug 8, 2013 10:11 PM
99bblazer99
Jul 4, 2012 04:13 PM
JediKnight2
Apr 4, 2008 12:44 PM
okmomw/blazer
Jun 29, 2006 12:56 PM
