99 zr2 hard right turn and abs light comes on
i have a 99 zr2 and the abs light comes on when i hard right hand turn what would cause this to come on and also the abs makes pedel move on dry pavment what would cause that to happen as well
thanks guys
thanks guys
![Big Grin](https://blazerforum.com/forum/images/smilies/biggrin.gif)
You may have a faulty wheel speed senor. You need to get it scanned for an ABS code.
I would get the computer scanned for codes to get an idea where to look for the problem...
After that I would check the sensor wires, sensor and wheel bearings for excessive wear. If the sensors get a lot of dirt between the sensor and the reluctor it will throw a code also, so you would have to remove the sensors to clean them. I would also think that if yourfront wheel bearings are worn enough to change the measurement between the sensor and the reluctor it would also throw a code at the proper front wheel...then you should check the front bearing/hub for wear with the proper equipment.
The turning the wheel part sounds like what happened to mine. The wire is broken at the mounting clamp.
kmartin
16
01-02-2023 09:06 AM
Big Ted
04-07-2012 07:01 PM
Seabbatical
07-11-2009 02:30 AM
posjimmy
12-23-2007 08:35 PM
Deezy
10-25-2007 08:58 PM
