About to be back in a Blazer - please remind me of all the common issues to look for
Old Aug 27, 2013 | 12:39 PM
jimspahr@msn.com's Avatar
I believe the top three problems are leaking FI spider'a, leaking intake manifolds, and fuel pumps. I think the issues involving the fuel pump and the Intake Manifold have been addressed already. I don't think the issue of the spider distribution has been mentioned. Starting in 1996 and with the VIN 8th character of 'W', the spider in the intake manifold had poppet valves which would over time get clogged up and leak. Look for a Blazer with a VIN 8th character of 'X' and you will have the new, improved spider fuel distribution system without the poppet valves. By the way, the older style W vehicles can be upgraded for about $200.00 in parts to the newer style FI system. You could do the intake manifold replacement and the spider upgrade at the same time
Old Aug 27, 2013 | 01:47 PM
burned's Avatar
burned is on a distinguished road
Pitman arm, idler arm, lower ball joints, lower intake gasket, fuel pump, 3rd seat handle likes to break, A/C compressors tend to leak at the seam, distributor gear wears, wiper pulse control board has crap solder joints, oil cooler lines leak.... some of the things off the top of my head.
Old Aug 27, 2013 | 01:50 PM
burned's Avatar
Forgot to add door pins wear out also.
Old Aug 31, 2013 | 11:39 AM
Jaylo's Avatar
Jaylo is on a distinguished road
ABS vehicle speed sensors (vss). When the vss on transfer case goes out ur ABS lite & engine lite come on. Transmission acts funny as well with vss problem.
Brian Lyford
Jan 31, 2013 11:31 PM
dwhittaker
Mar 14, 2011 02:18 PM
Kevin Jensen
Jul 26, 2010 03:59 PM
gaspricessuckk
Apr 27, 2010 06:59 AM
NoTyme
Apr 5, 2009 08:21 PM
