ABS Activation at low speed
Alright I have read all the Service bulletins on this issue but I want to make sure my case relates.
My ABS does enguage at 5-6 mph while braking but my concern is that my abs light never turned on. I t became pretty dangerious so I pulled the fuse until I can correctly find the source of the issue.
I know I need to try each side with a volt meter now.
I cleaned the drivers side with no luck. Could I disconnect each side at a time and would that lead me to the source of my issues?
Heres the service bulletin.
https://blazerforum.com/forum/tech-articles-diy-29/brakes-low-speed-below-5-mph-abs-activation-%5Bspeed-sensor-testing-adjustment%5D-26941/
-Brian
-Brian
Sounds like a match. I'm not sure if it is mentioned in the tech article, but you can also measure the resistance of the sensor. Too high of a resistance and the sensor is bad as well.
Yes sir. I need to go back though both hubs and test them now.
Pipewrench Dale
11-10-2014 06:16 PM
hace1
09-08-2011 08:43 PM
Clay_Assassin
12-12-2010 08:04 PM
