Abs brakes
Old Apr 19, 2023 | 12:25 PM
Jmack's Avatar
Jmack is on a distinguished road
Default Abs brakes
1998 Blazer 4wd 4dr
My brakes sometimes don’t stop unless i pump them. Abs light is on. I it ok to pull the abs fuse to see if the abs is the problem?
Old Apr 19, 2023 | 05:38 PM
The first thing is to do a proper diagnosis.
Have the brakes been worked on lately? Have you inspected them? Have they been bleed recently? Have you noticed any loss of brake fluid? Have you had the error codes read?
Even with the ABS system disabled, you should still be able to stop. The only difference is that you would be able to lock up the brakes instead of them pulsating.
An example of an issue that could cause an ABS light to come on is a brake in the circuit that monitors the wheel speed sensors.
Perhaps others can make other suggestions too.
Old Apr 27, 2023 | 08:09 AM
puttster's Avatar
agree ^^^ Symptoms suggest brake bleed is in order.
gmcgough12
Nov 3, 2014 01:33 PM
slaughterbaby
13
Sep 28, 2011 09:34 PM
dsmith9103
Sep 24, 2010 08:46 AM
scott96
Mar 26, 2009 05:46 PM
ivannj
14
Oct 28, 2008 03:04 PM
