ABS Brakes: Pros/Cons.
Old Nov 16, 2010 | 04:37 PM
Moores12345's Avatar
Moores12345 is on a distinguished road
Default ABS Brakes: Pros/Cons.
Alright so my ABS Brake Light comes on once in a while (not just on start up) so I just turn the truck off and than turn it back on and it goes away. Doesn't happen all that often. Every once in a while maybe 2-3 times a month or less. The front end was comepletly redone, everything. I haven't drove the Blazer in the snow yet cause I only got it this summer. ABS or Anti Lock Braking System I assume is to stop your vehicle from skiding when you have to brake.
I find most of the time when I turn into parking spaces or have to turn and brake that it kicks in and almost seems like she doesn't want to come to a stop. More times than not its when the wheels are turned. Obviously ABS brakes is applied fully and not pumping the brake at all but weird how it grabs and makes that almost grinding noise.
Anyone else have any input on this?
Old Nov 16, 2010 | 06:24 PM
jbsnowboarder16's Avatar
jbsnowboarder16 is on a distinguished road
Chances are the sensor in the wheel is going bad, causing it to think that its starting to stop. Mine did that and it was the sensor in the drivers side front causing the ABS to fire when it shouldn't
Old Nov 16, 2010 | 08:24 PM
bandidolenny's Avatar
X2 on the front sensors... they may just need to be cleaned. (removed and wiped off)
Also check the condition of the wire leads to them as well.
Old Nov 18, 2010 | 01:42 PM
Were are the front sensors located to? 98' 4X4 4DR.
Thanks for help guys.
Old Nov 18, 2010 | 02:23 PM
In each front wheel hub/bearing assembly.
tomborsari
Lifting Tech
Nov 6, 2010 04:34 PM
taba5
Jun 14, 2010 06:27 PM
96chevblazer
May 5, 2009 04:14 PM
chevys rule
Jun 4, 2007 09:24 AM
m00nwater
Apr 23, 2007 12:58 AM
