ABS coming on !
Old Aug 16, 2014 | 06:57 AM
chvyscott67's Avatar
chvyscott67 is on a distinguished road
Default ABS coming on !
Hi yall, ive replaced a speed sensor and the whole hub with new sensor on the other side, and my brakes are still doing that, push you off the pedal thing when almost stopped, has anyone had this happen and what can i do ? Thanks !!!
Old Aug 16, 2014 | 09:49 PM
ABS activation below ~5 mph: If the ABS light does not come on, this is a very common problem. This TSB, (technical service bulletin) does not specifically mention your vehicle, but it does apply to it: http://ww2.justanswer.com/uploads/GM...s_bulletin.pdf
Old Aug 17, 2014 | 07:29 AM
thanks, but ive been thru all that already. i think im gone to try a new hub on the other side also, i hear many people have clearance problems with just sticking a new sensor down in there, hope it does the trick. id appreciate any other ideas !!
Old Aug 17, 2014 | 08:14 AM
rexazz2's Avatar
was there any sign of rust when you replaced just the sensor ?
If you remove the ABS relay it with shut down your ABS and put the ABS light on all the time but stop the butt puckering stops
Make sure you torque the hub assemblies
Old Aug 17, 2014 | 01:22 PM
If you've gone through the TSB and had satisfactory results, the problem is not the hub or the sensor.
Athlon2012
Nov 1, 2014 03:50 PM
Bobby_Lee
Apr 5, 2012 06:39 PM
stormshadow1
Apr 23, 2009 09:46 AM
zerokarma
Dec 6, 2007 01:55 PM
dusted800
Mar 28, 2007 06:28 PM
