abs light
Old Mar 12, 2011 | 10:09 AM
stunner4206's Avatar
stunner4206 is on a distinguished road
Exclamation abs light
So my 00 blazers abs light went on 3 days ago. At first it would just stay on for the first 3 miles or so. Now it always stays on. Occasionally when braking slow the abs engages and the brake pedal feels weird. By weird I mean it almost seems to go down all the way. I guess I'm trying to say the abs comes on. It has 131k miles. I have changed the front brakes and hubs before. I also installed new discs and brakes in the back about 3 months ago. Anyways I would like to know what I should be looking for in order to fix the problem. Any help would be appreciated. Thanks in advance...
Old Mar 12, 2011 | 10:29 AM
Lippyp's Avatar
Lippyp is on a distinguished road
I can't help you but I am interested in the answers as I have exactly the same problem. I've now pulled the fuse on the ABS for the time being as I nearly rammed someone when it happened in a traffic queue.
Old Mar 20, 2011 | 04:56 PM
jbordi's Avatar
jbordi is on a distinguished road
I had the same problem on my 01 blazer. I had abs modlue rebuilt by modulemaster.com. It fixed my problem. The KH 325 modlues are known to fail.
Old Mar 20, 2011 | 05:10 PM
warthogdriver's Avatar
could also be your hub sensor itself...they get dirty and corroded at base connection on hub...they can be cleaned and put back on...could also have a bad hub...the exciter ring could be giving you false reading....and the abs module could be bad.
i would check sensors first..easiest and cheapest fix...or have a brake shop do free inspection and have them tell you what is wrong....that one is my favorite.
Old Mar 20, 2011 | 07:16 PM
Here's a TSB that tells how to diagnose and repair it: http://ww2.justanswer.com/uploads/PE...533_blazer.pdf
Old Mar 20, 2011 | 07:18 PM
Brakes - Low Speed (below 5 MPH) ABS Activation
Whoops, Captain beat me to it.
Tinted
Mar 15, 2012 02:56 PM
damageinc98
Jul 12, 2010 10:47 PM
stormshadow1
Apr 23, 2009 09:46 AM
95_Blazer
Dec 6, 2007 09:44 AM
Deezy
Oct 25, 2007 08:58 PM
