abs light comes on heat shuts off
when i am driving down the road the abs light will come on and my fan will quit. its my moms car so i dont know a ton about it but thats what she told me anyways. could this be a ground or fuse, i did a new ignition switch about a year ago. also after the new ignition switch she can either use the radio or the cruise any ideas on that, did i get the wrong year ignition switch?
RE: abs light comes on heat shuts off
The ignition switch should not cause one feature to work only while another feature is not being used. Sounds like you have either a bad ground that is causing current to back feed through anything it can, or you have some crossed wires somewhere under the dash...
Let me see if I can dig up some wiring diagrams for the affected systems and see what is common to them.
*EDIT* - I couldn't find anything related between the HVAC fan and the ABS system... I'm still looking for some explaination about the cruise & radio.
kmartin
16
01-02-2023 09:06 AM
amp042
04-26-2013 06:44 PM
Big Ted
04-07-2012 07:01 PM
Seabbatical
07-11-2009 02:30 AM
chrissy
01-16-2007 02:00 PM
