ABS light on Dash won't go out
Old Sep 16, 2009 | 07:59 PM
cameronp29's Avatar
cameronp29 is an unknown quantity at this point
Does it cost much to have them hook up the abs computer?
Old Sep 16, 2009 | 09:10 PM
old skool luvr's Avatar
some places will do it for between $20 to $40. that's the one thing i liked about the OBDI system, any idiot could check their truck (or car), and just look up the codes for themselves.
ah, the good old days, hahahaha!
Old Sep 18, 2009 | 12:58 AM
ExplicitYourSelf's Avatar
ExplicitYourSelf is on a distinguished road
The (timken) hub I purchased came along with the sensor/harness & I took it to a break and alignment shop that my family & I have known for years. He diagnosed the abs system with the computer & mentioned that I have a bad abs computer. I will be sending my abs computer to that website that does the service for $130 soon... & will give you guys the results.
Old Sep 22, 2009 | 08:20 PM
ve3nsv's Avatar
ve3nsv is on a distinguished road
I just changed just my sensor on a 99 Jimmy 4x4 and it was a breeze and the sensor was around $55. Remove the wheel, remove the outer 18mm bolts holding the whole caliper assembly, pull the caliper off and tie it off to the side, pull the rotor off. Now you will see the ABS wheel sensor bolted to the hub assembly with one single allen head bolt. Remove the bolt and undo the 3 brackets holding the harness to the upper control arm and then unplug it up in the wheel well under the battery.
Reverse the process for the new one and your will be off to the races. The ABS light should go out as soon as the computer sees the proper operation of the new sensor as did mine.
As a side note I picked up my sensor from a local parts store here and I had to shim it as it was making contact with the hub. It took me a few tries as I had too large of an air gap and the ABS would engage under 15km/h. I finally got the spacing right and all is good so beware when buying cheap after market sensors.
Old Sep 22, 2009 | 11:55 PM
Before you replaced the sensor, did you ever take your car to get diagnosed?? If so what did they detect on your diagnoses??
Old Sep 23, 2009 | 02:14 AM
ve3nsv's Avatar
The wire had rotted off right at the sensor and the ABS light was on. No need for any expensive diagnostic tools for that repair.
Old Sep 23, 2009 | 11:31 PM
i think ExplicitYourSelf was wondering what code was thrown out for yours.
Tinted
Mar 15, 2012 02:56 PM
damageinc98
Jul 12, 2010 10:47 PM
stormshadow1
Apr 23, 2009 09:46 AM
Irish10Hockey
Nov 13, 2008 02:48 PM
Daninehnj
Feb 22, 2007 02:26 AM
