ABS light on ONLY when wheel at full turn
Old Nov 6, 2010 | 11:29 PM
aura1's Avatar
aura1 is on a distinguished road
Default ABS light on ONLY when wheel at full turn
I tried searching this and couldn't find anything sure footed. My 2000 blazer 2 door has an annoying ABS light that is coming on ONLY when the wheel is turned all the way to the left, and at first start up in the morning. I just had brakes replaced and since then have noticed my ABS engaging at low speeds when moving it the first time in the morning, this ABS light.
I know it could be the hub, but the drivers side hub was just replaced.
I'm lost.
Old Nov 6, 2010 | 11:37 PM
69chevelle's Avatar
69chevelle is on a distinguished road
I'm lost.
did you check the wires, make sure they are scured properly, not stretching at full lock or binding with anything?
Old Nov 7, 2010 | 08:54 AM
Sounds like you have a wire that is either being pinched or stretched (as mentioned) when you turn fully.
Besides the regular checks (resistance, mV-AC output when you spin the wheel per the tech article on the slow speed activation, etc), getting the ABS scanned should give you an indication of which side is at fault.
Old Nov 7, 2010 | 10:50 AM
aura1's Avatar
Well, it's somewhere to start! Today should be a warmer day so I might tear into her. I figured it could be a wire issue. Thanks guys!
iamchevyman5
Feb 28, 2011 04:35 PM
DetailersDomain
Detailing
Jan 21, 2011 07:09 PM
Hizapitt
Jul 14, 2010 07:23 PM
damageinc98
Jul 12, 2010 10:47 PM
Deezy
Oct 25, 2007 08:58 PM
