abs lock up?
1996 jimmy 4x4 when stopping on wet or slippery roads the brakes lock up and stay that way, till i put it in reverse and then they let go,no lights on dash or codes set,i pulled the abs fuses and it does not happen,not shure if its a sensor or mabey the controller,any ideas what could cause this?
brakes where serviced few mounths ago,there not the problem,work fine when the abs is unplugged,found out its the left front wheel that locks up and wount relese,not the calaper or any thing there,the abs moter runs and the truck stops fine,but the left wheel wount un lock,fooled arond with the dump valves by pushing them in and out and it let go,run fine stoped fine,seems when it locks up and i push pull the dump valve stems it releases, is this something that can be changed?or rebuilt,could it be the way the brakes where bled when the master was replaced?or do i have to change the whole unit out?
Tinted
Mar 15, 2012 02:56 PM
iamchevyman5
Feb 28, 2011 04:35 PM
92K5BLAZER
Jan 20, 2010 02:52 PM
stormshadow1
Apr 23, 2009 09:46 AM
