ABS only Light on at start
Old Oct 12, 2015 | 09:12 AM
Fusefinder's Avatar
Fusefinder is on a distinguished road
Default ABS only Light on at start
The vehicle had a pin hole leak in the drivers rear line, fluid was depleted from the reservoir. I repaired the leak (with double flair fittings) bled the lines (all 4) to where clean brake fluid came out and brakes seem to function correctly now.
However the ABS light only, comes on with the ignition key and stays on. I do not have a code reader that will retrieve ABS codes. Any ideas on where to start?
Edit: 2002 Chevy Blazer (S10 type/ not Trail Blazer) 4dr 4wd
Thanks!
Old Oct 12, 2015 | 10:20 AM
CWBDDSPC's Avatar
CWBDDSPC is on a distinguished road
Sounds like air got into the abs when the reservoir went dry. Your local auto parts store should be able to tell you the codes.
If it is just air in the abs system you can:
Option 1, find a friend or shop with a code reader with the ability to activate the automatic abs bleed. Then, bleed the lines again...
Option 2, find a safe patch of gravel road, parking lot etc and activate the abs system a few times. Then, bleed the lines again...
I would have the codes pulled and let us know for sure what they are. Never know, could be something else...
Hope that helps
Tinted
Mar 15, 2012 02:56 PM
aura1
Nov 7, 2010 10:50 AM
damageinc98
Jul 12, 2010 10:47 PM
stormshadow1
Apr 23, 2009 09:46 AM
95_Blazer
Dec 6, 2007 09:44 AM
