Abs problems
Old Nov 8, 2011 | 06:18 AM
99 blazer's Avatar
99 blazer is on a distinguished road
Default Abs problems
sometimes my abs light will come on and everything will work fine...other times the abs will kick in when slowing down and make it hard to stop..other times the light will be off and everything works like it should..
Im getting codes c0221 c0281 c0222 c0235 c0226 and c0223..
what could be the issue?
thanks
Old Nov 8, 2011 | 07:24 AM
I would start by checking for the proper mV-AC response from both the right & left sensors (>250mV-AC while rotating the wheel) at both the sensor connector and at the EBCM connector.
C0221 - Right Front Wheel Speed Sensor Circuit Open
C0222 - Right Front Wheel Speed Signal Missing
C0223 - Right Front Wheel Speed Signal Erratic
C0226 - Left Front Wheel Speed Signal Missing
C0235 - Rear Wheel Speed Signal Circuit Open
C0281 - Stop Lamp Switch Circuit
Tinted
Mar 15, 2012 02:56 PM
iamchevyman5
Feb 28, 2011 04:35 PM
stormshadow1
Apr 23, 2009 09:46 AM
upblazer95
Apr 4, 2009 08:27 PM
dusted800
Mar 30, 2007 07:37 PM
