ABS Problems
Old Apr 15, 2015 | 06:14 PM
Ren1914's Avatar
Ren1914 is on a distinguished road
Default ABS Problems
This last week I replaced the front hub assemblies, rotors, and brakes. Took it for a test drive, and everything works great, EXCEPT under hard braking. When the ABS kicks in, it's like the left and right front break are engaging at different times. The steering begins to jerk hard left-right-left-right, and it takes longer to stop than expected. There's also a whining sound coming from under the hood somewhere, like a little motor.
Any ideas? I've replaced hubs, rotors, and brakes before, but I've never seen this before.
Old Apr 16, 2015 | 11:48 AM
burned's Avatar
burned is on a distinguished road
Measure AC voltage and clean wheel speed sensor mounting surfaces.
1. Raise the vehicle on a hoist.
2. Disconnect both the front wheel speed sensor harness connectors.
3. Place a DVM across the terminals of each sensor connector.
4. Rotate the wheel with hand speed and measure the ACmV's. The reading should be at least 350 ACmV's.
5. If the reading is between 200 and 350 ACmV's, remove the wheel, caliper and rotor in order to gain access to the speed sensor.
6. Remove the wheel speed sensor and plug the hole to prevent debris from falling into the hub during service.
7. Clean the wheel speed sensor mounting surface using a wire brush, sand paper, emery cloth, ScotchBrite™ or other suitable material. Be sure to thoroughly clean the wheel speed sensor surface. There should be no rust or corrosion.
8. Check the sensor head to determine if it has been warped/distorted due to the corrosion build up or other causes. Check the mounting surface on the sensor head for flatness by placing it on the edge of a metal machinists scale or other suitable straight edge to measure the flatness. Check the sensor for flatness in multiple (minimum 3) positions/directions. If the sensor head is distorted, replace the sensor.
9. Apply (spray) two thin coats of the specified rust penetrating lubricant (corrosion inhibitor) to the complete sensor mounting surface on the bearing hub. Allow to dry for 3-5 minutes between coats. Use ONLY Rust Penetrating Lubricant, P/N 89022217 (Canadian P/N 89022218).
10. When the corrosion inhibitor is dry to the touch (about 10 minutes), apply a thin layer of bearing grease to the hub surface and sensor 0-ring prior to sensor installation. Use ONLY Wheel Bearing Lubricant, P/N 01051344 (Canadian P/N 993037).
11. Install either the original sensor or a new one in the hub and secure the sensor. Ensure that the sensor is seated flush against the hub.
12. Install the rotor, the caliper and the wheel.
13. Place the DVM across the sensor terminals and recheck the voltage while rotating the wheel by hand. The voltage should now read at least 350 ACmV's.
Old Apr 17, 2015 | 01:02 PM
Ren1914's Avatar
Thanks for the detailed info. Any hints on where to find the speed sensor connector in order to test (steps 2-5)? Or is that the ABS connection that goes to the hub?
Tinted
Mar 15, 2012 02:56 PM
iamchevyman5
Feb 28, 2011 04:35 PM
stormshadow1
Apr 23, 2009 09:46 AM
upblazer95
Apr 4, 2009 08:27 PM
dusted800
Mar 30, 2007 07:37 PM
