ABS scare 98 Blazer
ABS scare 98 Blazer
well after replacing the front right ABS sensor and putting out my ABS light I was driving down the road and came to a stop and the ABS kicked in .. was on good dry pavement, no lights came on, but the ABS is now kicking in everytime i slow down from about 12 mph and then quits when i actually get to a stop. the thing pulls hard left when it does this also. not really sure what is up with this but its scary.. any ideas on where to go? I had it scanned and there are no current codes showing for the ABS.
If the ABS light is out while driving, you've got the sensor close, but not perfect. If the signal from the sensor to the ABS unit isn't within range, the wheel will lock up below about 8 MPH, as you found out Without an ABS capable scan tool to watch each wheel speed, or check voltage output from the sensor, you'll have to dink with it until you get it right on. The option is replace the hub assembly, it comes with the sensor.
I have access to a snap-on scanner. what should be proper voltage from the sensors? what is the range i'm looking for? I can get the scanner and check it out. what a let down, I was so happy to get rid of the yellow light of doom only to now be worried if I'll be able to stop at the light. lol
I have the same problem but it just started doing it yesterday and I never even touxhed the abs sensors, my wheelbearing is howling a little bit but there is no play in the bearing I'm going to tighten it up and see if the howl goes away, but if its the gap then what would cause mine to go off if it hasnt been touched??
one word answer, rust.
rust builds up between the wire and the bearing and actually lifts it up away from the ring inside the bearing. so basically the way you fix it is take off the little bolt (should be a allen head bolt) holding the wire to the bearing and wire wheel the heck out of and re install it. or just replace the bearing and wire together.
you got about a 50/50 chance of getting that wire out of there in one piece anyways, sometimes a rust ring builds up and they wont come out
Tinted
03-15-2012 02:56 PM
iamchevyman5
02-28-2011 04:35 PM
stormshadow1
04-23-2009 09:46 AM
