ABS Sensor...Do I need it?
Just received a new front hub for my 99 Blazer LT 4wd. I did not come with a new abs sensor. Sensor was pictured with the hub, but did not come with it... Do I need a new sensor, or can I reuse the old one??
Shop wants $250.00 part & labor. I paid $78.00 for the hub.
I'm 79 years old, and pretty much worn out, but I can't afford the shop $'s, so I'm going to give it whiz!!! Just don't want to tear it down; then find I need the sensor; with no way to go get it.
Thanks
Thanks
If the sensor isn't damaged reuse it. I reused mine with no problems - however my new hubs were around $120.00 apiece - the cheaper hub at about the $70 to $80 range was the one without the magnitic ring so make sure new hub looks like the old one - luck to you
You should also make sure that you received a hub for the 1998 and newer trucks, and not the 97 and older. The 97 and older trucks used a hub where the hub has visible external teeth for the sensor, and the sensor is part of the dust shield, and came separately. The 98 and newer hubs have an internal sensor and no visible teeth. The sensor is removeable, but normally is purchased as part of the hub.
Sorry if my description is not very clear. I'll try and find pictures to clarify for you.
EDIT***
Here's a picture of a 97 and older hub:
![](https://blazerforum.com/forum/attachments/2nd-generation-s-series-1995-2005-tech-41/18683-abs-sensor-do-i-need-513061pic1.jpg?dateline=1386084837)
And a 98 and newer:
![](https://blazerforum.com/forum/attachments/2nd-generation-s-series-1995-2005-tech-41/18684-abs-sensor-do-i-need-98.05gmhubassyabstruckpic2.jpg?dateline=1386084837)
They're very similar, but you should be able to see that the newer style hub does not have teeth behind the mounting plate where the wheel studs are. If you did get a 98 and newer hub without a sensor there should be a small hole where the sensor mounts and you should be able to see the teeth inside the hole.
EDIT***
And a 98 and newer:
No worries. Glad we could help sort out your problem.
![Icon Angel](https://blazerforum.com/forum/images/smilies/icon_angel.gif)
Tinted
03-15-2012 02:56 PM
iamchevyman5
02-28-2011 04:35 PM
marketmagoo
11-21-2009 02:09 PM
stormshadow1
04-23-2009 09:46 AM
Kellen
10-27-2008 08:19 AM
