Abs system blocking booster
Old Jul 28, 2018 | 03:46 PM
xDestro's Avatar
xDestro is on a distinguished road
Default Abs system blocking booster
I was able to get the master cylinder out and the bolts to the booster out but the abs system is blocking it from coming out... Can I just unbolt the system and move it or do I need to take each brake line out?
it's a 2000 Chevy blazer 4wd
Old Jul 28, 2018 | 05:08 PM
xDestro's Avatar
I was able to get abs system out of the way buy the brake lines are still blocking it
Old Jul 28, 2018 | 08:08 PM
AJBert's Avatar
I didn't have to break any of the lines. It was tight but I was finally able to maneuver the boost out. Putting it back in was just as much of a PITA.
Old Jul 28, 2018 | 09:32 PM
xDestro's Avatar
u just watched a video of a guy saying he had to buy a tool to allow the ads system to open and close to be able to bleed the brakes... Is this true? Or can I just get it all back together and bleed normally?
Old Jul 28, 2018 | 09:36 PM
If you have air in the ABS pump, it needs to be bled with a scanner.
Old Jul 28, 2018 | 09:37 PM
xDestro's Avatar
so I'm assuming since I disconnected to brake lines from the abs there is air in the system? Is it hard to get a hold of a scanner and bleed the abs? Or maybe just be easier to get it towed to a shop to bleed it all?
Old Jul 29, 2018 | 05:52 PM
Try bleeding it first. If the pedal feels good, you're probably fine. If not, most decent shops will probably have what they need to do it. It's only like a five minute procedure. Unfortunately, most cheap scanners (and most of the ones you can borrow from auto parts stores) don't have that capability.
syfaz777
Nov 25, 2018 04:23 AM
95BlackGA
Jul 30, 2013 07:35 PM
lunghd
13
Mar 17, 2013 09:49 AM
RyanBiggs
Aug 18, 2011 07:27 PM
ComputerNerdBD
Jul 24, 2010 11:38 PM
